Just to throw yet another stick in the fire, or at a kleenex football player.
BOV's and DV's are different!
The mr2 does not have an oem BOV!!
it has an oem DV.
A DV is not adjustable and generally quite xxxx to use on turbos that move a lot of air
, such as ours
.as the spring tension in them is too weak and the boost pressure
-if high enough
- could push it open
-letting air escape!
They are fine for smaller turbo cars such as R5GTT
, Uno Turbo
, RST etc.
a DV would be something like a Bailey
& GGR Piston Type Dump Valve.
A bov is a DV thats adjustable
/ tunable via usually a
'Hard
/ Soft' spring
-such as the Greddy Type-r
, Sard R2D2 etc etc.
This allows you to increase
/ decrease tension on the spring that holds the BOV closed while on boost.
this is used to stop it from opening when it shouldnt.
If you was to run a bigger turbo/more PSi then you would poss want to increase the spring tension to keep the valve closed.
The reason some BOV's appear to chatter is because where the spring is usually setup to be slightly stiffer than that of a DV,
-say the spring is set to 5psi then you would need 6Psi of boost pressure to open the valve.
any less than that and the valve will stay shut and surge back through the turbo.
obv tho if it opens at 6psi of boost, then the boost pressure will instantly drop as pressure is released.
.causing surge aswel.
the only way to eliminate surge completly would be to loosen the BOV spring,but then as you reach high boost, it will open
/ leak boost air.
So baically you find a happy medium.
Also i do believe BOV's are designed to remain closed while on tickover, to stop metered air from escaping
(for cars with MAF sensor
-rev1&2) whereas DV's are open on tickover.
