Front Bumper:
Bumper Reinforcing bar: 52021-17020
Bumper foam: 52611-17010
Bumper skin: 52119-17900
Centre upper metal strip: 52521-17010
Side upper metal strip: 52522-17010
(2 off)
Bumper to wing metal strip
(RH): 52535-17010
(LH): 52536-17010
Centre lower metal strip: 52506-17010
For completeness seeing as I'm compiling the list
(Someone else is bound to dig this up in a search), for mk1b:
Bumper Reinforcing bar: 52021-17021
Bumper foam: 52611-17011
Bumper skin: 52119-17901
Centre upper metal strip: 52521-17011
Centre lower metal strip: 52506-17020
(All other parts same as mk1a above)
Standard fittings used:
Bolts for lower strip: 90109-06102
(9 off)
Nut for upper strips to body: 90179-06068
(6x for Centre, 2x for Left, 2x for Right)
Nuts for bumper to wing metal strips 90179-06097
(3 per side)
Lower bumper attaching bolts: 90119-12062
(2 off)
Upper bumper attaching bolts: 90119-10085
(2 off)
Look like locating pins of some kind for the upper strip: 90339-04018
(3 off)
If someone else with the EPC could check these for typos it'd be appreciated.
