thanks for your reply paul,you make sense in what you say but i cant think of any other reason why may engine did not detect the detonation in the cylinders ill give you all my details and mabey youll see something i dont.
1.bottom end
perfect crank balanced with forged crowler rods,forged pistons 86mil bore act 11lbs flywheel all assembled with arp studs
,full race big end bearings.
high flow oil pump and water pump.
2.
top end
hks head gasket,head ported and polished,standard cams,re shimmed.greddy timing belt.standard fuel system,standard boost.recon ct26(couldnt find a ct20)hks adj cam pulleys
,honed trottle pot.hks cone filter.
there is more but just iridium plugs and stuff like that.well hope you see somtin wrong here cause i cant figure it out.just seeing the pitting on the top of the pistons sent alarm bells ringing i only ever seen this in engines with automatic ignition timing.
thanks again
john
