phew! dont need all the head work afterall, the timing was off and when it went back to idling it was fine and no tapping.
so i think i need new ignition components, any idea why the ignition timing would stick?
its supposed to idle at 10-14 but it was stuck at 40 and jumps back down to 10 but takes a bit longer than it used to, maybe its just been sat for too long.
[Mk2] [Turbo] phew!
Re: [Mk2] [Turbo] phew!
Is it me or does this post hardly make any sense at all? Please could you explain it properly then maybe we can help. Cheers .
dawolf wrote:Is it me or does this post hardly make any sense at all? Please could you explain it properly then maybe we can help. Cheers .
agree, im a bit lost too
lol realy sorry guys,
ok, i start the car and the ignition timing on the power fc reads 40 and there is lots of tapping from the engine.
i let it idle for a few minutes and the timing drops back down to 10 and the tapping disappears.
what component would i have to replace to stop this from occurring
throttle position sensor?
mine was a bit erratic on idle, jumping from 9 btdc up to 15 then back down, i tryed turning the throttle position sensor about 1 degree anticlock wise and all was fine.
BUT DONT DO THIS UNLESS ONE OF THE GURUS CONFIRM IT AS IM JUST A BUILDER
throttle position sensor, i'll go check as i have the AVCR it tells you how many % its at, maybe that will tell me something
