[Mk2] [Turbo] blitz dump valve
ive just fitted a blitz dump valve on my rev 3 slightly tuned running higher boost but didnt sound very loud can you change the sound????
Re: [Mk2] [Turbo] blitz dump valve
try loosening the screw on the end, it could be too tight
Depends if its the early version or the late one......
Latest one is not adjustable!!
If you want more noise then turn your boost up
i have i think its running 1.2 bar
Then no i'm afraid.......
What revision is the car???
rev 3 i will get a pic up
do you have the filter attachment or the trumpet on???
The Blitz Bov's are just quiet nothing you can do really,
If you want loud just vent the stock BOV there very loud.
what do you mean vent the stock one?
Just take off the pipe that runs from the stock one back into the air intake. Done it on mine, and it is amazing. Bloody loud.
but don't forget to plumb the hole in the intake with something
Yep. Think 3's sell some proper bits of metal to go in it now. If not i went to homebase and found a plumbing bit that did the job perfectly.
nice one i will try that tomorrow i will keep you posted
Do we
We sometimes have spare plugs that you usualy get with a kit for an aftermarket bov........Or yes something can be fashnu'd(fashioned...sorry lol) to fit.
End of a broom handle does the trick too
i used a bottle top lid for now!! works a treat
Sure it was you guys? Little stainless steel bit for £15? I am nearly 23 now, memories not what it used to be... lol.
i have to admit that the baileys is cheap but does sounds good. Never had a problem myself with them on a rev 1. I do use a hks now and i have to say it's not as loud
i had a fensport dump valve on my rev 1 tubby sounded nice i thought the blitz was meant to be a real nice whoooosh sound
http://uk.youtube.com/watch?v=BiY_EfPrzEo this is what i thought it would sound like
