Check your boost!
Its getting cold out there, cold dense air
You've been warned!.
James
3S Service Centre wrote:Hi guys!
Check your boost!
Its getting cold out there, cold dense air= more boost, 3 calls in 1day talking about symptoms that very much sound like upset/damaged knock sensors.
James
PostPosted: Tue Nov 13, 2007 8:26 pm![]()
Post subject:
Hi
Yes if the boost is controlled by the powerfc.
What you need to do is going onto the commandor, Get it back to the Monitor, setting and etc window
Select Settings
Then BOOST
The setting which is highlighted, lower the boost value and your boost should drop
Any probs feel free to give us a ring
cheers ryan![]()
Tiamat wrote:Quick question to those in the know- excluding all the horror stories about extra power and being the wrong time of year
- is now the best time of year to set up my MBC?
Given the cold air would it be better to do it now rather than wait for spring.
michael wrote:Dan! Dan! Dan!
