just bought a set of 100w fog light bulbs, will these be ok for the wiring on the car? 91 g-limited
also am i supposed to have fogs that move when turning the wheel?
maximum wattage fog bulbs
Re: maximum wattage fog bulbs
I don't think the G-ltd got the movable fogs, just the JDM GT spec.
It's the inside of the fogs that move anyway - not the outside cover. Does your front fog switch on the dash have 2 positions or 3 positions? If it's only got an on/ off, then they're not movable.
As for 100w bulbs, are these legal? I thought the limit was 65w for road use. Of course you're free to have them for "off road" use...
I can't say whether the standard wiring will cope with this extra current being pulled through it though - you'd need to know how thick the wires were etc etc, and I don't.
Did you get the foglight cover off ok? apparently it's a bit tricky.
Ian
Ian
