[Mk2] [NA] Where is the electronic speedo sensor located ?
Feel rather stupid posting this, but for the life of me I can't find the speedo sensor in the engine bay. I guess it is somewhere around the gearbox/engine area, but if someone who knows can post up precisely where it is I'd be grateful. Thanks.
Re: [Mk2] [NA] Where is the electronic speedo sensor located ?
it's on the back side of the gearbox, with a 3-pin connector that faces upward. Should be just to the left of the engine mount that bolts to the rear crossmember.
Many thanks for that - Now found it !
Next question - Can I remove it without dismantling anything else ? It seems to be stuck at the moment.
Thanks again.
Thanks again.
