Hi all! I'm finding myself in need of a new drive shaft and CV assembly Does anyone know what other model twos use the same part? ie will a rev 2 NA shaft fit the rev 3 turbo?
Thanks for you help!
[Mk2] [Turbo] Tubby Drive Shaft
Re: [Mk2] [Turbo] Tubby Drive Shaft
IIRC turbo and N/A shafts are NOT interchangeable.
That sucks! would you know if the Rev 2 Turbo shafts will fit the rev 3 Turbo? Proper picking your brains now, lol!
rev3 turbo had(i think)an lsd fitted as standard,
rev2 turbo it was an option,
so you will have to figure out whether yours has an lsd as they are not interchangeable.
hth
hth
ive got every shaft that can be found on a 2, give me a call on monday and i will dig out the one you need.
