Can anyone point me to a guide on fitting a new front wing to an AW11?
I've only done one before and that was on a mate's Polo and was a bit quick and dirty. I've recently been playing with my spray gun I bought ages ago and reckon I'd like to have a crack at doing the wing myself, but I'm not sure how much trim and stuff needs to come off.
Thanks in advance,
Glenn
Front wing replacement
Re: Front wing replacement
I did one on my mk1a in April. I had the front bumper off at the same time (as it was being repaired) but you dont necessarily have to remove it. Its just a bit fiddly getting to the bolts that hold the wing to the slam panel.
2-3 bolts on slam panel
1 bolt at bottom of wing on side skirt
1 bolt at top near windscreen
4 along the top
An idea to remove the arch liner as well, as it gets in the way a bit
May need to take the front part of the side skirt off, as it helps for manueverability when putting it back on, unless you have the model with no side skirts of course.
Fairly easy to do. I did mine in half an hour
4 along the top
- Lauren
- IMOC Committee
Its a really straightforward job tbh.... nothing that difficult to it.
2020 GR Yaris - Circuit Pack
Thanks folks, sounds very straightforward.
As soon as I can get organised I'll start prepping the new wing.
Ta.
Ta.
I did both of mine earlier in the year, the only hard bit are the bolts which attach the bumper and valance to the wing. Mine were rusted solid and ended up having to dremel them off. It really is straightforward but be prepared for rusted solid bolts and you may shear some, especially the one at the bottom of the wing at the door, get yourself a 5mm drill and a 6mm tap before you start
I replaced one recently, and the only problem I had was I replaced the wing and did all the other bolts up, only to shear the one by the door!
Had to drill it out and re-tap and bolt. Was fine then...
http://karenphillipsracing.blogspot.com ... olted.html
Very easy to change the wing...
watch this video...if you can put up with Brewer's waffle then Edd China gets the job done.
http://www.youtube.com/watch?v=Snhv0kA2D8w
anyone recognise the bloke in the very stylish leather jacket at the end
Great timing on this thread - I'm about to take my offside front wing tonight for tinworm treatment.
Mk2 NA Rev1 -*- Mk2 Turbo Rev2 -*- Mk1 NA -*- Mk2 Turbo Rev 3 = all gone!
_______________________________________
"Cruisey, Sporty, more innovation, more adult. A Man In Dandism. Powered mid-ship specialty."
Prgoramme
Just watched the Wheeler Dealers prog on YouTube all the way through and that is amazing, especially what Ed did to those wheeels. Ended up looking on Autotrader to see if there were any cheap MK1s about (no).
I'm guessing that show is on a channel I don't get 'cos I don't have Sky.
Thank the fates for YouTube - essential viewing.
PS I don't mind Brewer, I'd rather listen to him talk common sense than Clarkson talking about the size of his endowment any day!
I've recently found out that I have fibreglass front wings, Does anyone know where they come from?
Wings
I wouldn't worry, just look after them.
Lighter and won't rust. Wish I had a pair.
whats the best place to get replacement front wings? mine are looking a little worse for wear!
