I know with the supras if you remove the cars you need something to control the boost.
mrtee wrote:the boost module from the unichip just lets you get a better map for the chip but does not control the boost..
The above statement is correct for Rev 1&2 but on a Rev3 the unichip can control the boost using the factory system
terrabyte-computing wrote:mrtee wrote:the boost module from the unichip just lets you get a better map for the chip but does not control the boost..
afennell wrote:Could it change the info given to the ecu so it does not open the waste gate?
With the unichip in place, I had extreme overboost, up to 1.2-1.3 bar.This was with no form of boost controller at all.
I initially put this down to an overly free flowing exhaust system
(3" D/P and 3" exhaust) but having put the cat back in for the MOT, I still had the overboost problem.
Once Luke had removed the unichip I had rock solid 0.7-0.8 bar boost.
I can only assume that the unichip had a
"bad" map on it that caused the overboost
Slarty, the reason you are on low boost I guess is because your on spring actuator pressure only and no bleed by the vsv.this could be because the unichip has been removed incorrectly.
