[Mk2] [Generic] ABS Problem
FizzyBlueMr2
Post by FizzyBlueMr2 »
Hi,
I had a problem in the past where very occasionally the ABS light would stay on after starting the car. Next time I started it it would be fine, and then stay that way for a good while....
....unfortunately the light is now back on. However, this time its coming on while driving. Its not been when braking etc, just when cruising on the motorway etc.
I can vaquely recall somewhere a way of getting codes out of the ABS controller in the same was as the ECU, and what they mean. Anybody have any info on this?
I'll check the obvious (low tyre pressure, break fluid, connectors etc) but would like to know what the car thinks is wrong..
Thanks.
