has anyone fitted any of these before as i will be fitting a set tommorow? just wondered if i will defo need spacers or not?
cheers
INFINITY 6500cs - 16.5cm
Re: INFINITY 6500cs - 16.5cm
yeah I stuck these components in the other month.![](./images/smilies/spacer.gif)
I did need to use a spacer
- but they came with 3 assorted spacers and brackets anyway.![](./images/smilies/spacer.gif)
I screwed the large plastic spacer ring to the door using 2 stock holes and one new hole
(in the spacer, not the door).![](./images/smilies/spacer.gif)
I then screwed a metal bracket to the spacer, and the speaker to the bracket with the smaller screws.![](./images/smilies/spacer.gif)
ps I use sellotape double sided sticky pads to stick the cross-over to the inside of the door
- under the hinge.![](./images/smilies/spacer.gif)
pps getting the tweeter out is a git
- but you only need to undo the front most wing mirror screw, and then bend the tweeter bracket round to undo it from behind.
Don't bother taking all three screws out
- they'll likely to start rounding.![](./images/smilies/spacer.gif)
hth
Ian
hth
Ian
I did need to use a spacer- but they came with 3 assorted spacers and brackets anyway
just recieved mine and the only spacer/bracket is the one which holds the mesh have not got any other brackets
![Confused :?](./images/smilies/icon_confused.gif)
dan1 wrote:I did need to use a spacer- but they came with 3 assorted spacers and brackets anyway
Same here, I got a pair last week and I havent got any additional spacers with them.
Dan
Pete
Dan- scary, I live in Walsall too
![Cool 8)](./images/smilies/icon_cool.gif)
![Dancing \:D/](./images/smilies/eusa_dance.gif)
![Question :?:](./images/smilies/icon_question.gif)
dan1 wrote:Dan- scary, I live in Walsall too
what 2 you got might have seen you around.
have you fitted yours yet
Nah, havent fitted em yet, Im selling my Pioneer head unit and buying an Alpine one, buying some new 4" for the rears, getting some custom sub boxes built, so once I get all the toys Ill be fitting it over a weekend and itll sound quality!!
I had a quality system in my NA, but Ive now got a Black Rev 2 1993 Turbo, sitting on 16s Split Rims with a scoop on the passengers side.
I live slap bang in the middle of Walsall
Which part of Walsall ru from?
dan1 wrote:but Ive now got a Black Rev 2 1993 Turbo, sitting on 16s Split Rims with a scoop on the passengers sidedont think i have seen you about, dindnt realise there was any residential by tesco? i live just down the road by the beverly hotel.
i see quite a lot of mr2's about should organize some local meets as there never seems to be anything happening rnd here? had a look at fitting speakers last night and have made some mdf spacers so will fit mine later today
Quality, you dont fancy knocking up another pair of MDF spacers do you???
Yep, if you look above chemist, thats my house!
Beverly Hotel, is that the one up by the school, I think they have dodgy over 30 single nights there.
WAsnt there loads of meets up by the Maccies at Cannock??
Pete
hmm maybe they're not the same.![](./images/smilies/spacer.gif)
I got either the Infinity 60.5cs or 65.5 cs set from DCDezign
- can't remember which now.
Sorry.![](./images/smilies/spacer.gif)
http://www.dcdezign.com/products_page.a ... "+speakers![](./images/smilies/spacer.gif)
The spacer was only 5mm or so wide though.![](./images/smilies/spacer.gif)
Ian
Ian
I had a set of 655CS and just made up a set of MDF spacers, only took 10mins.![](./images/smilies/spacer.gif)
![Image](http://www.philz.pwp.blueyonder.co.uk/images/ice/ice6.jpg)
