As title recently purchased a stage 2 ct26 hybrid turbo from matturbo,
i will be trying to
fit this sometime in the near future and i was wondering if there is a
howto for instance or if you peeps could give me some advice on fitting
eg order of taking the old crapper off and what to look out for when
fitting the new one,and where to get the gaskets from?
Also what kind of boost level can i safely run at with n1 exhaust and downpipe induction kit,avcr and uprated i/c for everyday use and the odd trip down the strip,(got to break into the 12s with this).
thanks in advance
cheers steve
[Mk2] [Turbo] Help or advice on fitting my hybrid turbo
Re: [Mk2] [Turbo] Help or advice on fitting my hybrid turbo
Check your AFR using a wideband to find out how much boost you should be safely running, also look at duty cycle of injectors for instance on your AVC-R.
The best gaskets will be sourced from Toyota - £13 or something for discharge flange gasket, and not sure on the other.
A job I couldn't be ar$ed with and let Ryan and his bro at 2bar tuning do the work for me
Hi mate if you dont mind me asking how much did the fitting cost you?
cheers steve
cheers steve
Come on people im pretty damn sure quite alot of people on here know what i need to know
You mean something like this? That is in the Knowledgebase at the top of the screen???
http://www.imoc.co.uk/forums/kb.php?mode=article&k=21
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
Thanks jaspa
im convinced that was the first place i looked
