Much appreciated for anyones help on this.
Craig
![Sad :(](./images/smilies/icon_sad.gif)
Dame wrote:Ok, start with the following:
1.Take a look under the car, are there any obvious oil leaks, are there any oil patches on the ground underneath?
2.Does the car emit a blue smoke when running? If so then it's burning oil.
3.If you want to check the piston rings, or bore wear, you'll need to get a garage to perform a compression test.
This will let you know if any oil is getting past the cylinders.
4.What's the porformance like? Has it dropped off recently.
Is the car difficult to start.
If the answer to either of these is yes, that could be a result of a loss of compression.
InFaMou$ wrote:Right first things first, were the hell do you get 0w40 from and secondly just an update..
When i checked the oil level today, the engine wascold
and the level was fine????? Any ideas cause when i check it and it was low the engine was hot??? am i just bein an idiot?
Craig
