[Mk2] [NA] Air Filter
does na have air filter, if so where is it?
Re: [Mk2] [NA] Air Filter
Passenger side of the engine bay, next to the radiator cap.
hmm, how you fit it?
filter look massive, only small box
Filter is quite big, from what I remember when I changed mine
(before fitting an induction kit) I had to disconnect the main pipe from the engine.
There's a guide for fitting an induction kit here:
http://www.mr2oc.co.uk/Knowledge_Base/o ... d=115.html
You'll only need up to step 9 though.
thank you, job all done
