Look at how the gasket of the original thermostat reaches the edges:
![Image](http://i130.photobucket.com/albums/p280/Ilpoto/coolant1.jpg)
![Image](http://i130.photobucket.com/albums/p280/Ilpoto/coolant2.jpg)
Is it supposed to be like that? I checked the product numbers but I've got the correct part
karammander wrote:one more thing i noticed from your pic, the bgb states that the pin on the rim of the thermo should be within 5degrees of the notch on the housing.
cheers karam
leeharding wrote:Whats the diff between a standard thermostat and a TRD one?? Apart from the cost??
Is it just constantly open letting the coolant run as it pleasees??
Turbo-G wrote:
Why do you keep randomly posting large red text? In another thread, everything you said made no sense at all![]()
