Can anyone please tell me how to remove the front fog lights on my 1991(uk)car.All the screws are solid with rust and i suspect i'll have to drill them out.Which screws are the ones that i need to drill out?There are two larger headed screws fairly fairly well recessed at the top and there is one smaller headed screw.What do i need to do when i've drilled out the screws............?
Dave
front fog light removal
Re: front fog light removal
right,i,ve drilled out the two larger screws and the light is loose from the top but seems to be held with something else lower down too????????any ideas please!!!
There's a peg at the bottom, just pull hard and it'll pop out.
Thanks Mark,i'll try that tomorrow.It does feel pretty well fixed in tho'.Is it fairly straight forward to get at the bulb after that?
Just had a look at your car mate-v.nice!!!!bet those exhausts sound good!what make is the exhaust system?
Regards
Dave
Regards
Dave
Yeah, it's really obvious once you've got the light out.
Thanks My friend, It's a blitz nur spec r, sounds awesome, especially above 5k!!
