oh dear, lol.
went to a dyno today just to check my fueling really.
got VERY strange results.
.at 15psi
(basically 1bar) i got 212whp but at
5k rpm![](./images/smilies/spacer.gif)
now obviously the ct20b should be peaking WAY past this, and in turn me seeing more power, tbh, i knew my peak hp wernt near other ct20b owners, ie, 6300-7k rpm.
.but wernt expecting 5k rpm, pmsl.
now to be fair, at 5k rpm, 212whp
(252bhp) aint to bad considering i should techinally have my power curve increasing all the way to 6500rpm-ish.
.and in turn be seeing normal
-ish power.
only good thing really was i hit 278lb of torque at 4k ish at around 14psi, so less than 1bar, which is sweet.
.but power behond 5k rpm is dead.
now i dont no whether my
"possible" actuator/wastegate issue is causing my low power, ie, turbo working ALOT harder than it should.
.dyno guy
(very nice bloke), thought i was running very rich, hense the dissappearance of power.
.he also said the car was mint
(well looked mint any going by the dyno figs, lol), and it hit more power at 5k rpm than he's seen before with other mr2s with similar mods at there dyno.
.so defo room for improvement.
just after some comments, feedback, ideas????
(mods if peeps wona know, ct20b, downpipe/exhaust, filter, rev3 ecu conversion, ebc, greddy ic)
graphs.
peak hp around 5k rpm.
.212whp(252bhp), 278lb of torque at 4k rpm.![](./images/smilies/spacer.gif)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/PHOT0001a.jpg)
wheel torque and wheel hp![](./images/smilies/spacer.gif)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/PHOT0002a.jpg)
wheel hp Vs AFR![](./images/smilies/spacer.gif)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/PHOT0003a.jpg)
AFR Vs Boost![](./images/smilies/spacer.gif)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/PHOT0004a.jpg)
