Hi JJ
yes its me, Derek, finally getting around to finishing off.
So how are you these days apart from collecting cars!
So if I understand, I have 4 injectors, each with a feed and an earth line, but at the resistor pack there is 1nr 12V feed and one earth for each injector.
Switching is done at the ecu.
I was hoping to use the exising loom and just mate the input of the resistor pack to the output, as this makes for a neater job.
I am concerned about cable insulation melting and circuits shorting.
Do you think it is feasible to take the live line and split it into 4, one for each injector then marry up the earths?
if so do you know which cable colour goes to which injector
cheers, and good to hear from you!
Derek
