I've just read the sticker on my GTS about a special procedure for topping up the coolant and wondered what this is and if there are any other special things I ought to know about?
Cheers.
![Cool 8)](./images/smilies/icon_cool.gif)
W0mbat wrote:use toyotas coolant.dont EVER use water.
there are several bleed valves for getting rid of airlocks in the system and there IS a procedure to follow to do it, especially when totally draining and recharging the coolant.
two bleed valves are on the rad(i think) one on
(near) the engine and maybe one somewhere else.
so that you can bleed air of of the system
(it is a BIG system after all what with the rad up front)
there is a document detailing all this but i can't remember where it is.
darn u johnny u beat me to it.![]()
and yes, i had toyota re-charge my system and still it sometimes runs lumpy on idle.![]()
Lauren wrote:
Actually any glycol based coolant will do fine.It is not necessary to buy longlife at toyota prices.
JappyBeast wrote:I heard it has to be RED and not Blue also.
Lauren wrote:JappyBeast wrote:I heard it has to be RED and not Blue also.
Yep the colour makes a massive difference..
Mr Two wrote:I've been to Toyota dealer today for antifreeze for mine and they said i needed red.My car is U.K.
£12 for 5ltrs ready mixed.Do not use just water on its own!!!
