Strange noise
Strange noise
Hi all, After doing alot of work to my car, i decided to start it up for the first time in quite a while. I then noticed a pulsating squeaking kind of noise coming from the cambelt side. What are the possibilities of a tensioner bearing causing this? is there anything else that makes this kind of noise? chris
Re: Strange noise
Assuming it went with engine speed are you sure it wasn't the alternator belt?
Re: Strange noise
yeah it gets higher with the revs. im going to have a look properly tomorrow. chris
