Will,
What aftermarket bumper are you going for? it's worth bearing in mind that most copies aren't going to be like OEM stuff, even some manufacturers kits aren't such great quality.
.I'd say expect some fitment work needed to get it to fit, they usually test fit one kit to a car before they produce a run and not all cars are identical.
My Border front end was a perfect kit near side, but off-side it needed a bit of work.
.the rest of the kit went straight on with no problems.
Also I'd say you won't get anything with it
(unless it's the Greddy front lip or something) as it'll replace the stock item so will re-use the stock nuts/bolts etc.
You'll prob find it'll just be a bumper that's counter sunk in the right places.
Hope that helps, buying body parts can be a hit and miss experience.
