heater pipes leaking
stevek
Post by stevek »
bought my rev 1 turbo two years ago did a complete engine rebuild loads of new parts on a very tight budget just got it going now i have a water leak metal pipes for the heater that run above the tank.can someone tell me how much they are.and does anyone other than toyota make them.
Regards Steve
THE DUKE
Re: heater pipes leaking
Post by THE DUKE »
From Toyota they cost a Kidney and the bottom half of your lung. Most guys replace with high temp thick water hose. Plus if you want to remove the metal ones for new you'll have to drop the fuel tank which is a biatch... :)
pnjmcc
Post by pnjmcc »
Hi Stevek,
Have a look in the Knowledge Base I am sure theres a "how to" in there on bypassing these pipes.
For piece of mind I did mine about 2.5 years ago and its still going strong
Regards
PaulM
92 G-Ltd.
stevek
Post by stevek »
Thanks for the reply rang toyota for prices £270 including discount & vat
will check out the how to guide.
Regards Steve
cravex
Post by cravex »
If toyota will do it for £270 go for it! My local toyota quoted me £2000!!!!!
I got it fixed with heater hose by 3S in the end for £230 (iirc) so for a dealer price that's a bargain!
stevek
Post by stevek »
The price just for the pipes £270 not for fitting.
think i'll buy some heater hose and do it that way.
stevek
Post by stevek »
Can anyone who has replaced the metal heater pipes with rubber hose let me know where to source some from.
thanks Steve
lower
Post by lower »
most motor factors sell if from off a coil. I bought mine from halfords when i did it about 4 years ago.
stevek wrote:Can anyone who has replaced the metal heater pipes with rubber hose let me know where to source some from.
thanks Steve
stevek
Post by stevek »
thanks for the info,cars up on ramps waiting,another job for the w/end.
Regard Steve
EarL
Post by EarL »
Had mine done about 2 years ago, and replaced with stainless. :wink:
