UK MR2 Idling Query...............!
BlueTurbo
Post by BlueTurbo »
Hi,
a mate has a mk2 MR2 2.0 UK GT. The problem is every now and then when driving and pulling up to a junction / slowing down the rev fluctuates between 300-1000rpm.. once or twice it has even almost died down the ignition lights come on but he revs it a little then its ok.........
ANY IDEAS? CAR IS COMPLETELY STANDARD UK S REG.
CHEERS
BlueTurbo
Re: UK MR2 Idling Query...............!
Post by BlueTurbo »
SOME1.....................? ANYONE.......................?
Car is idling slightly lumpy every now and then.......... revs wonder between 500-900rpm.
CHeers
mj
Post by mj »
My old mr2 was doing this turned out to be leaking inlet pipe.
adamshaw
Post by adamshaw »
Could be a number of things!
I have heard that a lot of cars do tend to do this though
dan9
Post by dan9 »
Could be an air leak in the inlet system somewhere - check all the hoses etc
spindle
Post by spindle »
My car has the exact same problem. sometimes it does cut out completely though. it's a rev 2 n/a import. i can't see any obvious air leaks. any other suggestions?
BlueTurbo
Post by BlueTurbo »
got it seen to and the mechanic reckons its the idle speed control vale - or something like that..
got quoted from MrT 180quid..!!!!!!!!!!!!!!!!!!!1
