Thanks,
Nathan
nathanfreke wrote:I know of one person on here that cracked his block but wanna hear of any other horror stories!! If you did, what power was it at? How long did it last? And what was the year of the block???
Thanks,
Nathan
BenF wrote:nathanfreke wrote:I know of one person on here that cracked his block but wanna hear of any other horror stories!! If you did, what power was it at? How long did it last? And what was the year of the block???
Thanks,
Nathan
Its happened to a few rev3's running 300-330 bhp.V8Killer here was unlucky enough to have that problem.
Rev1 and Rev2's have a different cast block and don't seem to have
a similar issue.
[SiG] wrote:Damn! Hope my Rev2 will be ok pushing about 380@fly.Kept it instead of switching to a Rev3
'cause I hear the blocks are
*generally* a little stronger.
Guess I'll find out soon
ENSMR2 wrote:I think that'll be ok mate.
[SiG] wrote:ENSMR2 wrote:I think that'll be ok mate.
Any chance of a guarantee?
Kept mine as standard bores too, for safety more than anything
V8Killer wrote:Cracked mine at less then 400BHP too..
.infact only about 320 odd BHP!!!
Spacey wrote:Very interested in this thread.I'm building a 400bhp rev 3 based engine with a
.5mm overbore.
Off to the.com boreds to do some reading then
[-o<
ENSMR2 wrote:Spacey wrote:Very interested in this thread.I'm building a 400bhp rev 3 based engine with a
.5mm overbore.
[-o<
I wouldn't over bore a stock block.
Mushin, Neil.What size pistons did you have?
I was speaking to Tony at Fensport and he said you shouldn't bore it out to fit bigger pistons as you are making a weak block weaker.They had problems running 87mm pistons
(with a stroker kit) on a thickwalled block.
Thats why they went down to 2.1
(going from 87mm pistons to 86mm).
I wouldn't go bigger pistons on our blocks.From what Tony was saying.
87mm pistons or 86.5 are ok on thick walled blocks but when you go stroker on a thick walled block is when you get the problems on them.
Should have got a kit where the 2.2 is all in the stroke
(like mine
Stock blocks I'd go stock size pistons.
Or get a thick walled block like I have![]()
screech wrote:or cheaper and stronger than a thickwalled block get a sleeved block like i did
i agree on the overboring, that's why i sleeved mine, not too keen on the idea of wekening mr2 blocks that are knwon to crack
