Need some help with this one people! sorry it long but please read!!
Ok, I took my car to my machanic with a water leak.
The pipe with the leak was in a really hard place to get to and said they had to bits of the engine apart to do it so i thought it a good idea to sort some other stuff out while why were at it, so the follow was done to my car:
Water pipe replaced
Rev3 recon gearbox LSD with drive shaft
Helix clutch kit
CAM BELT
They took the engine out to do this work, then when they put it all back togther the engine management light has come on all the time, it runs like sh*t, it pinks, no boost what so ever! They got an ecu reading and it kept saying the knock sensor.
They checked the
"everything" and it was fine, so they said the knock sensor was knackered so they have replaced that and still the same!!
I took it to my mate for a second opinion, he said the cam belt had to much slack is probably causing the timing to go out.
I looked at the belt and it was quite loose!! So i took it back and told him what my other friend said.
He has spent the whole day on it today and says the timing belt is fine and timing in general and is running out of idea as to what the problem is.
PLEASE HELP and ideas appreciated
Dave
