A few questions relating to my MK2 Rev1 tubby which I cant find definitie answers to by searching.
I appreciate all help you can offer me! Smile
I drove my MR2 tonight for the first time in the wet.
The car had been sitting around all day in the rain, so I guess rain had been getting into the engine bay through the vents on top.
For the first 3 or 4 miles it ran like a bag of s**t, farting, burping, missing and popping.
I assume this is a problem with the water and electrics.
Is it due to the car needing a good service? IE, distributor cap, plugs, leads etc?
How can I tell if my car has been
"de-limited"? It's got 110 mph speedo face and reads the speed in MPH pretty accurately.
The odometer reads in kilometers.
The car goes over 110mph pretty comfortably.
This makes me think it's been
"de-limited".
The issue I'm having is the handling of the car.
The steering is really light at speed and is actually quite scary.
Is this because it hasn't been
"de-limited" correctly and the power-steering is still active over 60mph?
(I'm gaining this info from what i've read around on the forums).
If this is the case, how can I check, and how can I limit it back again, until I get time to carry out this modification correctly?
I have one speaker behind the passenger seat.
Does this mean I have a passive or active stereo system?
Lighting.
I have an aftermarket toggle switch to control high and low beam for the front lights.
Why isn't this wired in with the main lighting stalk? Is the japenese spec different from the UK, thus making all imports having to carry out this modification? Or did the previous owner bodge something up?
The center tunnel which runs through the passenger compartment.
What should be at the rear below the glass? I have screw-holes where something used to reside, but I havent seen any photos yet of that section of the car.
Thats it for the moment, thanks!
![Smile :)](./images/smilies/icon_smile.gif)
