I still even getting interference when the amp/radio is not even on, never used to get this so perhaps it could be a bad earth connection, failing this it might have to be a suppressor.
Ian
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
Paul 'Shmed' Medway wrote:This seems odd![]()
So you're saying that even with all the speaker terminals disconnected from the amp, the interference is coming from the speakers?
Also, the power steering pump is driven by the engine and doesn't do anything with the engine off.![]()
My P/s pump whines when the engine is on
