Hi
I have an MR2 Mk1 87 Jap import supercharger, can anyone tell me if air con was standard equipment as mine doesn't have it.
Also where they fitted with a LSD ?
Air con and supercharger, is it std equipment ???
Re: Air con and supercharger, is it std equipment ???
manta7 wrote:Hi
Where's Lauren when you need her
Watch out OZ here I come !!
Will I do
It's unusual to find an SC without aircon....though some have climate control and others don't. Perhaps you have the lightweight model? Are your windows manual rather than electric?
Secondly no, SCs were not sold with LSD as standard. However, a lot do have them, usually aftermarket though I believe it was a dealer option too. Easiest way to check is find a slippy surface, put it in a low gear and give it a little welly, if you're pulled round you've got it
T
T
Never known an SC not to have AC apart from the lightweight editions Toni has already mentioned. Perhaps this pic will help identify whether you do, or dont have it?
As you can see in the top left of the control panel, you can see A/C and Economy buttons. If you've got them - try pressing them
As for LSD, 99% sure you WONT have it, as your car is an 86. But why not do the test Toni has already said? Its fun!
Wayne
Wayne
"If in doubt - just make the numbers up!"
tonigmr2 wrote:Will I do
T
My car (rev1 tubby) doesnt have LSD - I checked the gearbox code on the ID panel located in the spare wheel well - but when it was icy i thought it would be fun to give it some slippery welly in a straight line and ended up facing the other way instantly. I'm now wondering if it has been changed for a LSD :S
(I'm also wondering if I should patent the name 'Slippery Welly' before someone nicks it )
Manta7, I have an SC. If you want AC I would gladly remove mine and sell all the components for a reasonable sum....
Regarding LSD. The gearbox code on my chassis suggests that I don't have LSD. However when I jack up the rear of the car and turn one rear wheel, the other one turns in the same direction, suggesting that I do have LSD. Confused!
- Lauren
- IMOC Committee
Icsunonove wrote:Manta7, I have an SC. If you want AC I would gladly remove mine and sell all the components for a reasonable sum....
If after jacking it up and with the car in neutral you turn one wheel and the other goes the same way, you have an LSD.
I think LSDs for the SC were either fitted as aftermarket or as a dealer (i'm guessing TRD) option.
Retrofitting AC is a bit of a nightmare tbh. Not only do you have all the pipework to do there is all the wiring as well. I'm not saying it can't be done, but it is by no means easy.
With that in mind, though its nice to have AC for the UK i'd say it isn't really worth it.
Indeed, I've removed all the AC from mine - the pump weighs about 10kgs!
T
T
waynestoyotamr2 wrote:
Wayne
whats that switch you can see through the steering wheel for? i dont have one of them on my mk1.
Porl''
Looks like a parking light switch. Not all MK1s have them.
T
T
tonigmr2 wrote:Looks like a parking light switch. Not all MK1s have them.
T
Well Done Toni - but sorry, you dont win a prize!
