Which boost gauge to get?
Dont think my car is running 100%, so thought id invest in a boost gauge to see what shes boosting at. Question is which one and how much do i pay? Looked on ebay and theres LOADS just dont know whats good and whats not! I have a 1993 rev 2 tubby. Should it be around 10psi? Im new to this tubby thing, so pardon me for asking but whats that in 'bar' (0.5? 0.7? etc) And whats the diff between bar and psi?! Sorry if i sound stupid...need a turbo lesson! Oh and what are they like to fit? DIY job or pay someone? Cheers in advance!
Re: Which boost gauge to get?
I believe the best boost guage to get is the HKS boost guage, i also like the different sizes too!
bar and psi is kinda the same thing, people tend to use different ways to explain what they are running at... Rev 2 should be about 6 - 7 psi i think, which = 0.5/0.6 bar !
rev 2 should boost more than 6-7psi since my rev 1 boosted 8-9 satandard on the rollers, i bought a apexi el boost gauge, i think this one is good because its very slim, only about 25mm and a nice display which is very accurate. but then its up to u.there are a lot of bar to psi converters on the net do a search and you should find one.
cheers karam
cheers karam
karammander mine was boosting standard at about 0.5/0.6 bar
which is about 6/7 psi right?
I think rev 2's are standard set that way, pretty much most people ive spoken too 0.5 - 0.6 bar is normal
Cheers guys. What about fitting them though? Is it a difficult job?
darrenmr2 wrote:Cheers guys. What about fitting them though? Is it a difficult job?
I think it looks abit fiddly, but i didnt fit my boost guage it came with the car
best to wait for someone with experience who has fitted there's
btw got any pics of your car?
No pics yet sorry what gauge do i need... mechanical or electronic? Just looking on ebay now... so many to choose from and so much variation in price so confused!
http://www.2kracing.com/index.php/cPath/476_490
These are the type that most people have
including myself
http://www.2kracing.com/images/face_whi ... _gauge.jpg
here's my type i have
including myself
BLOODUK wrote:karammander mine was boosting standard at about 0.5/0.6 bar
1 Bar = 14psi roughly.
0.5 = 7psi (ie wastegate pressure if the ECU thinks there is a problem)
0.7 = 10psi When ECU is happy.
Time consuming more than difficult - you need to run vaccum hose though from the engine bay (T off from just below the pressure sensor next to the diagnostics port) through to the dash.
John Helps a few years back did this excellent write up :
http://www.btinternet.com/~netsurf/mr2t ... #HKS_gauge
i like the 60mm greddy stuff, quality isn't cheap .... its priceless
if you want a nice EGT to go with it i got them in stcok.
I've got an electronic, digital boost gauge which I got for £40 from POTN.. it did take AGES to turn up, so I'm reluctant to order off the same company again though!
Its good, easy to see and easy to fit, although I'm only boosting 9.1psi, although I reckon that there is a slight boost leak somewhere, which I'm yet to trace. I was under the impression Rev1s and 2s boosted to 10psi and Rev3's boosted to 12psi (stock)
The safest boost for a Rev1 is around 15psi, and Rev3 is 18 I've heard.. although some people run more/less depending on when they need it.
Best invest in an oil temp/pressure gauge too, as if your oil stops, your turbo and engine will follow suit shortly!
Another option is the replacement of the std boost guage with an alternative of same size. I did this using the Omori mechanical boost guage but this involves more fitting than mounting on the dash or on pillar including some cutting of clock housing. At the same time I replaced the clock dials with white Lockwoods as the clocks have to be removed in order to fit guage. Cleaner appearance IMO.
