Can anyone shed any light on the difference between Greddy Intercooler and a Trust unit?
They seem to be pretty similar and around the same money (Trust actually slightly cheaper) but has anyone used one and got an opinion on which to go for?
Appreciate any advice....
Trust/Greddy intercooler difference?
Re: Trust/Greddy intercooler difference?
They are the same!
THE DUKE wrote:They are the same!
pmsl,
yeh mate, there the same thing....
trust=greddy
greddy=trust
As im lead to beleive one is japanese the other is american.
products are the same tho.
What like Honda and Accura?
Thats what im told... Think trust is the Jap version and Greddy is the US
Lets play spot the muppet!
ME! Jus been looking through both sites and the pat numbers are identical for both Trust and Greddy, just ordered the Trust from Oz. Even that guy couldnt explain the difference, those crazy Japanese!
Oh well thanks for the help guys, makes the morning so much more interesting!
did you look at the Berk intercooler. Slightly better performance but only £350.
Yeah iv seen the Berk one, but the previous posts iv read said it was untested at the moment and people were a bit dubious about the figures...
So think im jus playin it safe, dont matter coz iv got the Treddy/Grust on order now!
But thanks for the replies and opinions, all very interesting
How much if you dont mind me asking?
turbo dragon,
Just PM'd you with some details. For the rest of you here is a link with the test results of this unit
http://www.mr2oc.com/showthread.php?t=1 ... ntercooler
tubby_tony wrote:turbo dragon,
YES, BUT RESULTS BY THE PEEPS SELLING THEM!!!
course there not gona test them and then say, its produces less power.
until there is an independant test done properly, then its hard to believe the figures....
Seems to me like the dudes not trying to claim it's better but just saying for less money you get more or less the same performance.
I think it's great that people are trying to make intercooler options better. At the moment we're so limited that we're forced to pay way way over the top prices.
Friend of mine is worried about spending £400 on his 200sx cause it's one the higher spec ones lol.
£400 is well cheap in our world.
yeh i get that, same for less money...
but in the end you do get what you pay for.
just my 2psi...
just my 2psi...
"did you look at the Berk intercooler. Slightly better performance but only £350. "
That still not been proven yet, and personally i'm not buying the 20bhp increase from just a core change of the same size, Exspeically seeing intercoolers fall on there ar$e on a dyno anyway, lot of extra power from not alot of changes
Just my opinion, i want to see hard facts done on the road first before we all rush out and buy one. I've seen greddy/trust intercoolers handle 550rwhp on large gt35 turbo's proving the flow is there, but we've only seen these against almost standard cars. Could be another Pace CC for all we know.
Tim
xxxx
Tim
xxxx
Curious as to how it has not been proven when they have used the same car, same pipes, same strappings to the same rolling road and only changed the intercooler core which was a direct swap between the Berk and the Greddy. That sounds pretty damn well tested to me.
it just sounds to much of a gain.
They reported a 12rwhp gain so around 20bhp from just swapping the core, on an almost standard car. 20bhp increase gain on a standard car is quite alot.
My main problem with the testing is that its done on a dyno with very little air flow which makes intercoolers prietty much usless, Most large dyno fans produce a 70mph air flow, where dyno runs are taken place at the 1:1 gear ratio which is around 4th on our cars. Top of 4th results in around 130mph and with a 70mph airflow the numbers don't match up and result in heat soak, this is why intercoolers preform much better on the road and underperform on a dyno. Also remember those 70mph fan are the very large units placed at the front of the car, its impractiable to move those to the side so that air flow is going to be at best overestermated for intercooler flow. So now we've established that the air flow just wasn't present for these tests it seems thta the 20bhp increase was even less likely.
Also remember these new intercoolers are using a bar and plate design which is usually less effcient than the tube and fin versions offered by many japanese tuning companies, like the greddy.
This is where the high flow tests would show up any problems with the new core, ok having low down cooling but you also don't want a bottleneck at top end restricting power, thats what i ment when i said about we don't want another Pace Chargecooler as this suffered the same problem
Soon as we get some proven testing on this subject and if proven successful i'll be stocking some, until then i'm sticking with the tried and test greddy units and they work everytime and are a good piece of kit.
Just my opinion
Tim
xxxx
Just my opinion
Tim
xxxx
tubby_tony wrote:Curious as to how it has not been proven when they have used the same car, same pipes, same strappings to the same rolling road and only changed the intercooler core which was a direct swap between the Berk and the Greddy. That sounds pretty damn well tested to me.
yes mate, but who carried out these tests???
the place bleeding selling them....
Was the Berk unit and the GReddy unit tested using the same std fan from the mk2 turbo?
