Thought i would try resetting the ECU to see if it would sort any running probs out.
![Question :?:](./images/smilies/icon_question.gif)
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Im really worried ive knackered something, how can i sort it now? Any ideas or suggestions would be great, help me out people please!
Leeroy wrote:Here's a how to on Jonty's site(hope you don't mind J
A core function of the ECU is to keep an eye on fuelling and in addition to the standard map(set by Toyota in the factory) the ECU learns and adapts depending on factors like fuel quality, knocking, and climatic factors.
Over a period of time, the ECU may develop a conservative fuelling map which robs the car of performance
(or if a problem occurs, e.g.
bad fuel or an engine safety scenario.
Although the ECU continually adapts, it's very slow at doing so and can be reset to speed up the process.
Preferably after a drive(and the car now at full operating temperature), park, remove the key, and wait a couple of minutes.
In the engine bay is a fuse box
-- remove the 7.5A ECU-B and 15A EFI fuses.
In the front compartment
(not the cabin), remove the 7.5A ECU-B fuse.
and then wait for at least two minutes before replacing them.
With the fuses re-seated you can start the car and go for a drive, and being already warmed up you can drive the car hard if you wish
(showing the ECU exactly how it should be fuelling!)
Don't be alarmed if the car is sluggish at first-- the ECU has been reset and is having to learn from scratch.
If it's reset when the car is cold, the lack of performance and hesitation will be more noticeable, but will still pass after a good 10-15 minute journey where the throttle can be exercised.
