Clutch & brake fluid for Rev3
stevel
Post by stevel »
Evening
I am looking to have my clutch & brake fluid replaced shortly. Now I know you can put DOT 5.1 in for the brakes but can you use the same for the clutch?
JohnnyC
Re: Clutch & brake fluid for Rev3
Post by JohnnyC »
I remember reading in an owners manual (can't remember which one off the top of my head) that said for brakes use Dot 3 or Dot 4, and for the clutch use Dot 3.
But I can't really see why you can't use Dot 4 or 5.1.
Sorry, I've not been much help, I'd like to know the answer too :?
BenF
Premium Member
Post by BenF »
It shouldn't make any difference. Personally, I'd put DOT 3 or 4 in as it doesn't asborb water as quickly as DOT5.1.
Given that its for the clutch, it shouldn't get hot - so there should be no chance for the clutch fluid getting hot and boiling.
