[Mk2 Turbo] WIDE TYRES..
thai boxer
Post by thai boxer »
Hi guys,
Soz if this has already come up, but whats the widest tyre size you can get on rev2 Tubbys in a 35/18 profile without any damage??
245?? 255??
Thanx!! :wink:
Gregg.
jonb-
Re: [Mk2 Turbo] WIDE TYRES..
Post by jonb- »
Depends on offset and alloy width......
I run 215/35 18 on 7.5j @ 45et and i rub at the front.
nutter
Post by nutter »
I run 225/35/18s on the rear. I've heard you can run 245/35's but a slight bit of arch fettling would be required. In fact since fitting my koni setup the rear of my car is sitting a bit lower and the inside of the arches are rubbing against the top of the tyre.....
thai boxer
Nice one cheers guys. I'm currently running 215/35/18 front and 225/35/18 rear with a 35 offset and 7.5 width (I think).
Thanx. :wink:
