Mk2 NA Engine problems
deleted
Re: Mk2 NA Engine problems
double check everythings connected back up,id be willing to bet the fault is self inflicted.
.check there isnt an air leak on the inlet side somewhere,lambda sensor hooked back up? just go back over everything on the engine install,im pretty sure thats whats wrong.
Also do a fault code pull.
.that might shed more light.
deleted
