Any help is apreciated!!
Nathan
Mikejc wrote:Given that you are running a Rev3 you already have an oil catch can of sorts..
.the little black coke can sized thing on left hand side of the throttle body.
Once the blow by gases have passed through this they are then fed back into the intake system just before the turbo.
I found that on my own car the blow by gas being fed back in to the system was mixing with the tiny particles that were getting passed the Blitz air filter, thus leaving a nasty sludge like compond around the intake leading up to the turbo and around the turbo inlet itself!To sort the problem I have now fitted a Cusco catch can and no longer recirc the gases back into the intake.
Instead i'm now venting directly from the outlet of the catch can to the ground via a long hose,
(not stictly legal I know
If you don't fancy venting to ground you could always buy yourself an oil breather filter for around
£20
The end result is a spotless intake, in my own case at least![]()
Good luck,
Mikejc
