![Embarassed :oops:](./images/smilies/icon_redface.gif)
![Question :?:](./images/smilies/icon_question.gif)
Lauren wrote:The idle should normally drop slightly.![]()
as kelvyn says it may need re-gassing, but wouldn't a 91 car use R12?
This is the evil stuff with all the CFCs so you can't get it anymore.You can use a newer refrigerant but you will likely have to replace your seals throughout the system, so you may be looking at a
£300 job, in which case its probably not worth doing.
