Why oils lose viscosity with use
oilman
IMOC Affiliated Company
Post by oilman »
Why do oils lose viscosity with use?
Viscosity Index Improvers.
An oils viscosity will decrease as the engine temperature rises. Viscosity Index Improvers are added to reduce this thinning. They are a key addative in the production of multigrade oils.
VI Improvers are heat sensitive long chain, high molecular weight polymers that minimise the viscosity loss of the oil at high temperatures. They work like springs, coiled at low temperatures and uncoiling at high temperatures. This makes the molecules larger (at high temps) which increases internal resistance within the thinning oil. They in effect "fight back" against the viscosity loss in the oil.
"Shearing"
The long chain molecules in VI Improvers are prone to "shearing" with use which reduces their ability to prevent the oil from losing viscosity. This "shearing" occurs when shear stress ruptures the long chain molecules and converts them to shorter, lower weight molecules. The shorter, lower weight molecules offer less resistance to flow and their ability to maintain viscosity is reduced.
This shearing not only reduces the viscosity of the oil but can cause piston ring sticking (due to deposits), increased oil consumption and increased engine wear.
Like basestock quality, VI Improvers also vary in quality. As with many items the more you pay, the better the finished article and more expensive, usually synthetic oils are likely to incorporate better VI improvers. All other things being equal the less VI improver an oil contains, the better it will stay in grade by resisting viscosity loss.
Which oils require more VI Improvers?
There are two scenarios where large amounts of these polymers are required as a rule.
Firstly in "wide viscosity span" multigrades. By this I mean that the difference between the lower "W" number and the higher number is large for example 5w-50 (diff 45) and 10w-60 (diff 50) are what is termed as "wide viscosity span" oils.
Narrow viscosity oils like 0w-30 (diff 30) or 5w-40 (diff 35) require far less VI Improvers and therefore are less prone to "shearing".
Secondly, mineral and hydrocracked (petroleum synthetic oils) require
more VI Improvers than proper PAO/Ester (Group IV or V) synthetic oils
as they have a higher inherent VI to begin with, this is due to
differences in the molecular straucture of the synthetic base oils
compared to mineral oils
It is a fact that many synthetics require significantly less VI Improver to work as a multigrade and are therefore less prone to viscosty loss by shearing.
Simon
Use the code IMR2OCUK and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ register for news and offers
email: [email protected]
phone: 01209 202944
Frustrated Pilot
Re: Why oils lose viscosity with use
Post by Frustrated Pilot »
=D> fantastic.... again a top quality thread by oil man.
:oops: what should i be using for my tubby ?? :oops:
:mrgreen:
Cliff
Oil recommendation
Post by Cliff »
I use Silkolene Pro S 15W 50 if that helps.
Frustrated Pilot
cheers dude.. whens the next event? pm me
oilman
Post by oilman »
Silkolene PRO S 10w-50 if it's modded and used on track, if not then PRO S 5w-40.
Simon
phone: 01209 202944
Cliff
Oil Recommendation
Post by Cliff »
oilman wrote:Silkolene PRO S 10w-50 if it's modded and used on track, if not then PRO S 5w-40.
Simon
Oops, just checked and I also use Silkolene Pro S 10W 50.
Goldy
Post by Goldy »
is 5w 30 fully synthetic ok to use on an regular n/a engine?
MR2Mania
Post by MR2Mania »
Nice post, oilman.
What do you think of Mobil 1 Motorsport (15w-50)? Also, what do you think of the 76 Racing oils (20w-50)?
Dino
Click here for MR2 Mania Website
oilman
Post by oilman »
Goldy wrote:is 5w 30 fully synthetic ok to use on an regular n/a engine?
5w-30 or 5w-40 is fine as long as the car is not heavily modded.
Simon
phone: 01209 202944
oilman
Post by oilman »
MR2Mania wrote:Nice post, oilman.
10w-50 or 15w-50 if the car is tracked or heavily modded. 20w-50 is too thick at cold start causing excessive wear.
Simon
phone: 01209 202944
DotNetter
Post by DotNetter »
Hi Oilman
Having read this article + the copied article now in the KB, I'm thinking of changing my oil to 0W 40 for the winter months.
This is based on the idea that the lower 0W will provide better protection during cold starts where the engine will take longer to reach temp due to colder weather.
Is this good logic or is the weather of little issue?
I'd also be interested to know how long it takes oil to reach temp rather than the engine coolant which drives the temp gauge (unless it's that temp sensor on the engine bay lid :-k )
btw, I have a rev1 NA with only 2 mods; a Mongoose exhaust and K&N filter.
Regards
Wayne
oilman
Post by oilman »
DotNetter wrote:Hi Oilman
Regards
Wayne
Wayne,
Yes a good 0w-40 or 5w-40 does not matter which is great for good cold start protection and fine for the na, so your thinking along the right track.
It depends on the car, but it only takes about 10 to 15 min to get the oil up to temp.
Cheers.
phone: 01209 202944
Return to “Opie Oils”
