ldavies83 wrote:that bolt is a pig, 10mm ring spanner does it! but with me it was a nights soak of wd40 that freed it eventually, I even ordered a replacement bolt from MrT, didnt need it eventually, so its going spare! but you will have to slacken that off
Cheers Leigh
- that was the key to the job.
Looking at the pic that Tom posted above, I thought some wierd and wonderful Torx socket was going to be needed, and molegrips weren't shifting it
- but you're right, a 12 sided 10mm ring spanner with a DIY extension freed it off nicely
We got the belt back on, left the idler loose and turned the engine over on the starter to get the belt nicely tensioned again
We pulled the HT lead from the coil to stop the engine starting
when we started the engine all you could hear was Crack
Crack
Crack.
The car's owner thought that was the sound of valves being shattered
but I could see some imressive 2-3cm long sparks crawling over the top of the ignitor coil through the condensation
Good news is that its all back together again and not leaking
- we put the belts and idlers back on
(but not the cam covers) and the car seems fine
- water system remains pressurised, no coolant leaks.
We've just got to remove the belts, re-install the timing belt covers and the job will be done
Tom
- one thing I saw from your photos was that you had the top timing belt cover off
- do you run your car like this normally?
