Bubbling/gurgling noise after a run
rev3gt
Post by rev3gt »
My car makes an intermitant gurgling noise after a good run (car turned of) sounds like air escaping or water boiling.
Is this normal or anything to wory about?
thanks :D
dj_davo
Re: Bubbling/gurgling noise after a run
Post by dj_davo »
quite normal fella.
all that pipework running from the back to the front etc. :)
blue2
Post by blue2 »
I get that while Im driving sometimes. Sounds like gurgling from the expansion tank. Never had any probs with it.
JUIC'IN
Post by JUIC'IN »
Undo the petrol cap and i bet you it stops. :tongue:
smiffy1982
Post by smiffy1982 »
mine does this also, can feel the car shaking slightly from it to, sud it be gurgling this bad? lol
Mine does it too, quite normal
raptor95GTS
Post by raptor95GTS »
its the coolant bubbling into the expansion bottle after you have shut the engine down. All that heat in the engine block continues to heat up the coolant which is no longer circulating causing it to expand into the expansion bottle.
stevel
Post by stevel »
I had this noise quite a lot but when i put a new TRD rad cap on the noise went.
Maybe a coincidence but i have put it down to that.
rev3gt
Post by rev3gt »
cheers for the replys im glad its nothing to worry about.
