As above really.
I went to replace the distributor cap and rotor arm on my (as far as I'm aware) bog standard UK MK2 Rev1 N/A but found the supplied dizzy cap had too small a central hole for the King lead.
Were there multiple different specs... Rev1 different to Rev2? Both different to Rev3 and on?
My mechanic's supplier says they only have the one part number listed.
Any help as always is greatly appreciated.
Rob.
How many different dizzy caps/leads through the Revs?
Re: How many different dizzy caps/leads through the Revs?
if you don't get an answer here, post on https://mr2oc.co.uk/ and they may be able to sort you out
Just order one from TCB they will sort you.
Thanks for the replies guys.
Now have a genuine Toyota one sitting on my table ready to go on courtesy of MR2 Ben.
