Hub centre bore ... 60.00 or 60.10?
HighwayStar
Post by HighwayStar »
As per the title really.
Can anyone confirm the mk2 hub is a 60.1mm centre bore and 5 x 114.3 hole pattern.
I'm thinking of changing my 15mm rear spacers for 12mm or 10mm instead and can't remember what the specs are
Many thanks
dansREV2turbo
Re: Hub centre bore ... 60.00 or 60.10?
Post by dansREV2turbo »
Yes you're right. 60.1mm centre bore and 114.3 PCD .
HighwayStar
Thanks you sir!
Thought I had it right but it's always best to check I find.
:D
