Hey Guys,
I'm not too far from upgrading my current suspension setup from D2 coilovers to standard-ish setup on my daily driver REV3 Tubby.
The roads are getting worse here in Ireland and I'm getting older
Having an eye on the yellow Bilsteins (B6), but not entirely sure what to expect from them.
Would these be much comfortable for everyday driving than a cheap-ish coilover setup?
I originally wanted to get standard rebuild-able struts, restore them and try few shocks in the future like Koni's and such, but I found it impossible to buy them in reasonable condition.
New ones are discontinued as per TCB, MR-MR2 only has very rusty ones and he says they are not really suitable for turbo anyway. (some size/height difference)
The other question are the springs. I have no idea what to get.
TCB got KYB standards which I might try, but I don't want my car look like a 4x4
I read a lot and I can rule out H&R springs for sure.
I would like a comfortable setup which are not lifting the chassis too much.
This is my current height on 17's rear(235/45), 16's front(205/45)
I would like similar height or could be a little higher.
I think I might need -20mm drop springs, but that's just guess.
Any input is appreciated.
Cheers,
Julius
Springs and struts
Re: Springs and struts
Interesting, I too changed from the D2 coil-overs around 5 years ago for similar reasons. I got hold of some rebuildable struts from GTSChris' drag car when he was still in business, absolute bargain and one of the best decisions I've made for the car.
Not sure that there is any fruit to the story of them not being suitable due to height/size issues, mine have been just fine (also on a rev 3 turbo), so don't discount them for that reason
As to springs, I tried Tein springs but they were very very harsh, especially at the front. Ironically I ended up swapping them for the H&R set you've heard bad reports about! After around a month of bedding in they settled very evenly front and rear. I've since put around 20,000 miles on them and can't fault the ride. On this note, I must confess I've always been perplexed by the negative talk around H&R, they are a quality product that was still in great condition when I changed the dampers last year. Regards to the ride height, mine sits very very similar to the photo you have shown.
As to dampers, for 4 of the years running them I had tokico inserts front and rear (I think), but have since changed to KYB excelG inserts which are adequate for my needs, especially with the Wilhelm geometry kit.
Just to note on my setup, I'm running 16" GTR/GTST wheels.
Hey mate,
Thank you very kindly for your reply!
Wish I could have got some OE rebuldable struts, but I will stick now with yellow Bilsteins. They gotta be good enough. Already on their way
I've seen H&R is decent, they also have spacers and their own coilovers. However, when I was doing my research, anytime H&R springs came up they were called very harsh, same as with Teins. Some also complained that the front was sitting much higher then the rear with H&R.
If I can source them for cheap, I think I will start my Bilstein journey with standard KYB springs and I will go from there.
Thanks for confirming the height so if I will go with lowering springs, I know I need 20mm types.
Already have an eye on Eibach Pro-kit, but will try KYB standards first.
Other than the harshness, were you happy with the D2s?
I am very happy with them at higher speeds on reasonably good roads.
Cheers,
Julius
Cheers,
Julius
- IMOC Moderator
Hi "Beans"
When I had the Cosmos young wilkies old car virtually rebuilt, I put yellow billies on, I'm not sure what springs are I put in on...dooh.
But she sorn'd now so going to swap over to the others I had on the std struts, as the ones on are a tad harsh, on a good road it handles superb, since some "Settling" it's better, so I'd say yellows OK maybe experimentation with "softer" springs
Regards Brian
Regards Brian
I had also read the issue of front and rear height differences...I wonder if the issue is use of them with the wrong strut bodies, I'll have to have a look at the intended year use when I get a chance as it has been bugging me! I suspect most people are using them on late body non-rebuildable struts as they are more common.
Your plan sounds spot on though
I was always happy with the front but was never satisfied with the rear, the spring rate was probably not the issue but it was certainly under damped, it had a tendency to oscillate and never quite balance when taking certain repeated loads/bumps. I think it's actually very difficult to get the damping on the MR2 right, especially when starting with mostly after-market components.
One thing I would say - be very wary of lowering without correcting the roll centre and associated front and rear track control rod heights. I've come to the opinion that it is next to impossible to appreciate the importance of correct suspension geometry when trying to improve your drive by changing springs/dampers. Improvements you feel by the ride being stiffer and less roll often blur out the negatives - most importantly bump steer, particularly from lowering the rear. Lowering the car AND correcting the geometry to match that new height, transforms the driving experience and I felt like an absolute nitwit that I had a geometry kit sat on a shelf for the best part of 2 years because I didn't think it would make THAT much of a difference.
I'm rambling, tl/dr - your plan like a great step in the right direction, just don't forget it can get better still For reference here's the link to Alex's kit and associated development:
https://wilhelmraceworks.com/suspension-geometry-kit
Thanks for the replies!
I also though that different struts would contribute to front-rear height differences.
Maybe no surprise as there are so many different part numbers for only one corner.
For example: Front Left NA+Turbo:
48520-17100, 48520-17120, 48520-17121, 48520-09025, 48520-19035, 48520-19056, 48520-0W020, 48520-19065 , 48520-19055
I was happy with the handling when lowered without the Wilhelm kit, but for sure it would be better.
I was thinking to get them, bu my worry is the exposed pivot points (spherical bearing?) on the arms.
Longevity is a key factor to me. My 2 is my daily and there are weeks when I drive 600kms
Will let you all know how I got on.
Blimey, yes that is a lot of variations!!
Definitely right to be worried about those exposed spherical bearings, I'm so surprised that Alex hasn't suggested people use rubber boots which you can stretch over - although he doesn't market it toward road use and for track usage I imagine exposed joints are just fine. The boots I put on early this year have held up great so far to a good mix of daily city and weekend cross country use, you can find them by tapping in 'rose joint dust cover' or similar into eBay and they will fit something like this:
Keep us posted how you get on, always good to have a review for the next poor soul that searches this topic in years to come!
Wow this is awesome! Never knew these existed.
Thanks a lot!
Thanks a lot!
yokomomr4bx wrote: ↑Mon Nov 22, 2021 9:45 am
We will try that when we start working on the new '1998 project next week, got to finish installing the suspension from 4Wheelonline onto the Jeep first this weekend.
Got the Yellow Bilsteins installed couple weeks ago with KYB RD5460 and RD1613, I'm pretty happy with it.
They are only a little softer my my coilovers were, but you can feel the quality is higher.
Rebound is much more controlled. I mean the wheels doesn't kick back that violently on certain bumps/imperfections on the road.
I can/could take speed bumps faster now.
I suppose it would be the best to drive it on 15's, but that's not gonna happen.
As for fast cornering, I'm not sure yet because so I also got new tires (from Conti Prem Contact 6 to Bridgestone Turanza T005) and I still have to find the good pressures for these new tires. (Currently 1.9bar front and 2.4 rear)
Not to mention these new tires are XL and the previous were not. So there are many variables.
Body roll is a little more than it used to be, but that's expected due to the softer KYB springs and higher ride height.
In fact the front are pretty high still. 17's in the rear and 16's front doesn't help either with arch gap. Eibachs are on the way
My addition of DIY spring insulators also raised it by 2mm
With absolute 0km in the front. There rear springs already had few hundred kms in them at this stage
Front height dropped a little since, so its more acceptable.
I will definitely change the front springs, but might leave the rears as is. I want equal height/arch gap front and rear.
Also tried a 5mm spacer on the rears and I really liked the outcome. With these KYB spring it will be no problem to add spacers. Got the longer studs, I will install them along with the spacers in the near future.
With 5mm spacer:
Without spacer:
With 5mm spacer:
Without spacer:
Great progress and interesting use of spring insulators, I haven't come across this before, what's the purpose/theory behind it?
I agree the 17" rears and 16" aren't going to do any favours for arch gap! I know you've just bought new tyres but...might be worth pushing the sidewall out to a 50 or even a 55 on the front - the 55 would push the total sidewall profile a little higher (122.75mm) than the current rear (105.75mm) but it would still be around 10/15mm less in total diameter.
The rear looks spot on for 17's.
I think the hardest thing with suspension setups on the Mk2 is getting the front to be the right height and soft enough and the rear to be suitably damped - personally I think you're on the right track with struts and springs vs coil-overs, but I know there are plenty of coil-over successes out there
Thanks!
Spring insulators are a must if you want less noise and vibration in the cabin.
Our 2s got one on the front (top of the spring) (48157-17020), I just added extra on the bottom because more is better.
Rears got them too in the means of the top mount which is part rubber.
I added them to my coilovers as well, it made day and night difference there.
I get your idea about 50 of 55 tires in the front, but I don't want any higher sidewall than it is already.
I think I found the best balance between looks, performance and comfort.
Hopefully the Eibachs will sort it out. If not and I will have enough travel left on the shock will start cutting springs
I think I nailed it.
Eibach Pro-kit front, KYB RD5460 rear.
Very happy with the look and height.
Handles and steers better with the front being lower compared to the higher KYB springs.
