Haynes Manual
[email protected]
Haynes Manual
Post by [email protected] »
Hi all
New MR2 Owner here, I'm after the Haynes manual. Unfortunately this is out of print and not available as PDF.
There are zero available on ebay and other sites.
Is anyone selling or would be able to scan a copy? I'm getting quite desperate at this point.
Thanks in advance
Mike
wilkie senior
Re: Haynes Manual
Post by wilkie senior »
Hi there welcome
Google BGB (Big Green Book) MR2 MK1
Loads out there and or post any problems or request for anything specific on here memebrs will be only too pleased to help
try here you even have a choice http://manual.teq.org/
regards Brian
wilkie senior
Re: Haynes Manual
also here
the manuals will be us and elsewhere specific but in general this is what we all refer to
http://western.net.nz/wheels/mr2/mr2.htm
MR22
Re: Haynes Manual
Post by MR22 »
Cancelled
MR22
Re: Haynes Manual
Post by MR22 »
To access a Toyota Manual you could try the following:-
www.shinny.co.uk/88aw11.pdf
wilkie senior
Re: Haynes Manual
MR22 wrote:To access a Toyota Manual you could try the following:-
same as in the tech org link i forgot aboout marks links some are dead but basically all the links have the same info
but thanks for posting to assist a new member
Regards Brian
jimi
Re: Haynes Manual
Post by jimi »
All the MK1 BGB stuff is available here https://www.mr2oc.co.uk/download-cats/c ... 0-mk1.html
wilkie senior
Re: Haynes Manual
jimi wrote:All the MK1 BGB stuff is available here https://www.mr2oc.co.uk/download-cats/c ... 0-mk1.html
Hi Jimmy
I knew youd be along at some point cheers :-)
regards Brian
jimi
Re: Haynes Manual
Post by jimi »
How's tricks Brian ?
:lol: He posted on the OC as well, I did tell him he would be far better off with the BGB's rather than the Haynes book of lies :wink:
Jimi
wilkie senior
Re: Haynes Manual
Hi Jim
Just trying to keep the company going me & the rest of the board & management team, are having sleepless nights over it all, if lockdown doesnt lift for the hospitality side of the business (biggest part) we will be locking the doors & throwing away the keys.
But we have to remain positive !!!
Take care fella
BillyDS
Re: Haynes Manual
Post by BillyDS »
Looks like a good site to get Toyota manuals. Thanks
jimi
Re: Haynes Manual
Post by jimi »
Be aware that if you download the pdf in the link to shinny's storage, that the ecu diagnostic codes in it are not correct for a UK MK1 and all the parts referring to cats and EGR systems do not apply to UK spec cars.
If you use the link I posted you can download the 4A-GE engine manual ( which has the correct codes) and the correct electrical diagrams for a UK spec car
BillyDS
Re: Haynes Manual
Post by BillyDS »
jimi wrote:Be aware that if you download the pdf in the link to shinny's storage, that the ecu diagnostic codes in it are not correct for a UK MK1 and all the parts referring to cats and EGR systems do not apply to UK spec cars.
Thank you for the tip, jimi!
