[Mk2] [Turbo] Battery upgrade
MR2TRD8
Post by MR2TRD8 »
Any suggestions for an upgraded battery for a Mr2 turbo?
platmatt8
Re: [Mk2] [Turbo] Battery upgrade
Post by platmatt8 »
I swapped mine with a Halfords CB005 which is a 510cca 62ah
wilkie senior
Post by wilkie senior »
Mines a N/A but i got this
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
fills up the tray no complaints so far mind you I have a battery disconnector I disconnect the battery when car is in the garage
https://www.amazon.co.uk/Battery-Discon ... ive&sr=1-7
You can get cheaper on Ebay, had 2 no problems
these are better for the positioning to take the connector off
Last edited by wilkie senior on Tue Oct 20, 2020 10:29 am, edited 1 time in total.
SonicSW20
Post by SonicSW20 »
096 fits with a spacer underneath. Big heavy xxxxx though.
yokomomr4bx
Post by yokomomr4bx »
Same one Wilkie has, never failed :thumleft:
shinny
Post by shinny »
SonicSW20 wrote:096 fits with a spacer underneath. Big heavy xxxxx though.
Yup! I did it with a bit of cutting to the battery tray and a DIY tie-down bar, while madbasshunter used a 12mm spacer instead forums/viewtopic.php?p=1663981#1663981
I put a Bosch S5 008 in mine - 77Ah capacity with 780A cold cranking current. Sure it's a little heavier, but at least the extra weight is at the front :lol:
Return to “Electrical”
