Locked out of boot
Locked out of boot
I just arrived home with a 1998 2 litre GTi barn find MR2 for son. The boot did not open from inside. I was trying to fix by reconnecting the cable and whilst doing so also disconnected the linkage from the key lock. Like a dick I then shut the boot..!!!! I think I am screwed but any help on how to get in appreciated. So to recap the pull tab inside the car is disconnected and so now is the key operating mechanism...
Boot
Not a good place to be.....
If you've already removed the trim around the sides and back inside the boot then you just might have a chance through the indicator lens with a coat hanger tool and inspection camera if you've got one. This lens will come off from the outside ( the end triangular one, just levers/pulls off) and if you then remove the rubber grommet around the wiring leaving a hole of about 40mm dia to go through. The other rear light lenses won't come off though as the top screws are hidden by the boot lid....
If all this fails and you don't want to risk damage to the bootlid or rear panel, then you might have to cut an access hole in the boot floor after removing the silencer, heat shield etc.
Best of luck!!!
Best of luck!!!
Re: Locked out of boot
Thank you so much for the reply I will certainly give the indicator lens an go.
I cant believe I actually shut the boot lid after disconnecting the linkage to the key lock what a tw*t..!!
Welcome to the IMOC,
Good luck with the car and maybe show us some photos of you progress.
*admin you need to move this to correct section
Indeed welcome,
*** moved***
ha ha my first MR2 I could not understand why the boot would not go down, then upon trying to find my watch........ yep left my watch in the way doooh
Regards Brian
*** moved***
Regards Brian
