[Mk2] [Generic] Rev 1 n/a auto chassis - rev 3 turbo engine
mark_1992
Post by mark_1992 »
Hey guys looking for a little help, last October I had an accident in my rev 3 turbo that ended up making the mr2 a write off. I've found a rev 1 shell with very low miles and in better condition than my previous mr2 was. So the plan is to swap everything over including the engine. I have removed the engine and loom from the turbo mr2 at the passengers side connector. I'm not 100% sure if I need to remove the rest of the loom to make it work? I know the rev 1 has a mechanical speedo but except from that I'm not sure if it's the same? If I do need to remove the loom whats the best way to do it? Is there any other connectors that just unbolt like the one at the passengers side footwell?
Any help is greatly appreciated
