[Mk2] [Turbo] Central locking diagram
Keelanw
Post by Keelanw »
Might be a long shot but does anyone have a wiring diagram of the central locking loom for the mk2? Doesnt have to be a wiring diagram specific to the central locking as long as it has central locking loom/wires in it. Mine is acting up, passenger door key barrell will loc and unlock the 2 doors but drivers door key barrel will only lock and unlock the drivers one and to make it even more complicated the interior doors lock and unlock works for both doors so im thinking there must be just one wire somewhere connecting the dirvers door mechism or control to the passenger one damaged.
mr2garageswindon
Re: [Mk2] [Turbo] Central locking diagram
Post by mr2garageswindon »
Its most likely the switch on the back of the door lock itself faulty. They are avail to buy still.
You may be able to swap the passenger side to drivers side to test. I can't remember if they are handed or not.
Just checked MR2ben, they are £56 and not handed
, could try TCB also.
Pauln
Post by Pauln »
Here's a link to the wiring diagram I have for the door lock:
Wiring Diagram Door Lock
Hope that helps.
Paul
Keelanw
Post by Keelanw »
Thanks lads! Ill be going at it tomorrow and let ye know how things go. Hoping that the remote central locking might magicaly sort itself out if i get this sorted aswel 😂
Return to “Electrical”
