I am looking to replace the exhaust gasket that fits at the joint after the back backbox as the one on my REV3 Turbo seems to be leaking from there.
I had recently replaced the stock item for a mongoose type one a while ago and am pretty sure the garage didnt put a new gasket or even the old one back in As i noticed the sound but now with a cold morning start I can see the smoke coming up and out of the engine bay and one side of exhaust has considerable more smoke that the other side.
Looked on ICP and ebay and couldnt find any.
On a positive note the car is driving all good now with the replacement OEM Fuel pump and fuel tank
Exhaust gasket [where from? Rev3 Turbo]
Re: Exhaust gasket [where from? Rev3 Turbo]
I got new exhaust gaskets off ebay for my blue flame exhaust.
- IMOC Moderator
Hi I go to my local motor factors bought a few
I went to the local one and he started asking about width and bolt size etc which I didnt know so left empty handed.
- IMOC Moderator
i made an pattern of the flange and took the old one, off the shelf at andrew page & my local Raynors motor factor.
Sonds like you got a "unless ive got a requisition signed by 3 people I cannot process your request......computer says no, Unhelpful person!
I may have a spare with part number on the packet If i can find it Ill pop a post up
Regards Brian
Regards Brian
i'd appreciate that and yes it was suggested by the chap at the counter to take off the exhaust and measure which I said would mean booking at a garage paying labour just the get the measurement, then re-fitting and doing it all over again once I buy an item to fit
- IMOC Moderator
Hi im sure I have a spare packed in the 2 i will try to get down ti the secret location ha ha,
i can take a photo next to a ruler,..... maybe if i scan it and do it to a PDF 1:1 ?
you could print off and take it with you
drop me your email in a PM ill see what i can do to help
Regards Brian
Regards Brian
- IMOC Moderator
HI fella got it
Hopefully i can help you out
Regards Brian
Regards Brian
Generic 2 bolt 3 inch gaskets from eBay will work.
- IMOC Moderator
pics PM'd hope helps
